Results 1 to 8 of 8
Thread: Help,power steering flood !
    Jan 2005
    Denville,New Jersey
    Default Help,power steering flood !
    Has any one come across, a power steering leak in your 6.5 ?
    Feb 2012
    Pauline, SC
    Lines do burst, their is a cooler for the p/s as well....
    1993 Chevy K3500
    like us on Facebook
    Feb 2006
    Shaft seal started leaking on my pump. It was only 25 yrs. old. GM crap. No problem to replace the seal if you borrow the tool to pull the pulley from Autozone, etc.
    Jan 2005
    Denville,New Jersey
    Thanks for your replies!! It looks like the cover rusted thru in three pinholes along the bottom .I was only able to find it with dye, and yellow glasses. Has anyone repaird the cover with epoxy or solder? I tried epoxy along the bottom but the holes keep weeping fluid.
    Feb 2012
    Pauline, SC
    You can try and patch it, I would think a new one would last longer than a patched up rotten pump would...
    1993 Chevy K3500
    like us on Facebook
    Jan 2005
    Denville,New Jersey
    Default Flood continued:
    Now i see the replacement pump has only 2 places to connect the lines , where the original had 3. Do the 2 return lines get spliced together before they are fastened to the pump?
    You got a pump for a gasser, which has vacuum brake assist and no need for the additional return port. The pumps may or may not be the same otherwise, so I'd be very cautious using it. The pump demand is significantly greater with brake assist and power steering, vs. power steering alone. Unless you can verify the pumps are the same, the replacement you have shouldn't be used, even if it fits perfectly. If they the same, the returns can be Tee'd. However, if it didn't come out of the box with that accommodation, I'd strongly suspect it is simply the wrong pump.
    Jan 2005
    Denville,New Jersey
    Quote Originally Posted by Warren96 View Post
    Now that the pump is on the bench i can see that the shaft is also leaking.I also verified with the store and the factory that it is made for my truck.I would like to thank everyone who was kind enough to offer suggestions, they where a BIG help.
  1. NOS power steering pump
    By oneton in forum TDP Classified ad forum
    Last Post: 06-12-2016, 07:34
  2. loss of power steering and power brakes
    By 3ace in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-16-2014, 13:05
  3. power steering sensor problem?
    By fresburb in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-08-2007, 05:55
  4. Steering shaft/coupler questions
    By Randee of the Redwoods in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-18-2005, 16:23
  5. Is a play of 1/8th turn in the steering wheel "normal"
    By c5dura in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 07-19-2004, 07:11
