Thread: Help with $$$$ Build
    May 2020
    Okotoks, AB - Canada
    Default Help with $$$$ Build
    Hi Guys, I have a small fortune into this engine already, looking for some help from guys that have experience with turbos and tuning - as per my signature, I think I've got a great start but need to reconsider my turbo option for sure. I initially bought it for my cummins 6.7 but blew the motor and have this thing sitting new in box. I cant see it working in a set of twins or compounds right? Its kind of just a mid size turbo.
    Any and all suggestions would be appreciated!
    - New LLY Block bored 20 over
    -Empire Main caps with ARP Studs
    - Callies Race Star Crank
    - Crower Gen 2 Rods
    - Mahle Forged Pistons
    - Internally Balanced
    - Socal Stage 2 Heads/1 piece Valves & Heavy Springs
    - ARP Head Studs
    - Triple Layer Gaskets
    - Custom Reground Cam
    - 60% Exergy Sticks
    - Socal Dampner
    Have a Garrett GT4088R .95A/R... Turbo would be great for a 600-650, I'm after 800 RWHP as a daily driver, lil smoke, just clean tune.
    **Still Needed**
    - Turbo(s)
    -CP3
    -Maniflods
    - Pipe Kit
    - Lift Pump
    - Flexplate
    - Built Trans
    05 CC/Longbox 4x4 SRW
    May 2020
    Nobody has any suggestions, No Turbo guys out there or vendors that have experience and want to sell some parts?
    My first duramax build and obviously a new member here as I'm typically a Cummins guy - The cummins forum must be a bigger community with much more experienced enthusiasts.
    I am surprised to say the least
    - Crower Gen 2 Rods
    - ARP Head Studs
    - 60% Exergy Sticks
    - Socal Dampner
    **Still Needed**
    - Turbo(s)
    -CP3
    -Maniflods
    - Pipe Kit
    - Lift Pump
    - Flexplate
    - Built Trans
    My Guess is there aren't many looking for outrageous power builds.
    Most want modest gains with stock reliability.
    Contact Kennedy Diesel he would be the guy that may have some answers for you
    May 2020
    Perfect - much appreciated!
    - Crower Gen 2 Rods
    - ARP Head Studs
    - 60% Exergy Sticks
    - Socal Dampner
    **Still Needed**
    - Turbo(s)
    -CP3
    -Maniflods
    - Pipe Kit
    - Lift Pump
    - Flexplate
    - Built Trans
    Do you have a compressor map for this turbocharger?
    A lot can be inferred from compressor maps, including smoke, slow/fast spooling, power range, boost pressure, exhaust backpressure, EGTs and a lot more...
  1. 6.2 build up question
    By Vin82k3500 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-09-2012, 05:21
  2. 6.2l oily build up in intake m. HELP
    By julie in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-24-2011, 21:15
  3. 6.2 build question
    By btrapr in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-18-2010, 10:09
