4l80e tranny issues
I have a 1996 3500 6.5 diesel. the other day I changed out the neutral safety switch, cause old 1 was crack by wire harness(kinda corroded). Now with new switch in place, I have NO GEARS at all. (all gears worked before replaced). So then I redid the wire harness to safety switch and transmission cause both were in bad shape. Still NO GEARS.... (ENGINE RUNS & Transmission worked ok b4 putting in new switch) I NEED HELP PLEASE
- You may not post replies
- You may not edit your posts
Forum Rules
