This describes an HEUI fuel system (Hydraulic-Electric Unit Injector), which is common on the Powerstroke and T444E engines. Duramax engines don't use this. The 7.8L uses HPCR (High Pressure Common Rail), similar to the 6.6L.
I suspect the black fuel and oil loss are not likely related. There are few engine oil/fuel interfaces in Duramax engines, and almost always result in fuel contaminated engine oil when the barriers are breached, due to the differential pressures. The fuel return circuit doesn't interface with pressurized engine oil. Black fuel/filter screams external contamination, biological growth/death, or vandalism. I suggest an immediate biocide treatment, as a precautionary measure. Higher than normal oil consumption is normally related to excessive engine wear (traditional causes), closed-loop crankcase vent systems (later models), or turbo spindle seal failure. At engine idle, turbo oil leakage favors the intake, and under load it favors the exhaust. A simple plumbing examination can confirm or refute this. Laboratory sample testing of the fluids will determine which fluids may be mixing, and what external contamination may be present.
