My pleasure...
My pleasure...
Jeff
2013 Caprice PPV 6.0L
Good advice!
If you have a helper, you can pour clean new fluid into the PS reservoir to help stay ahead of the drop in fluid level. This'll help prevent the PS pump from sucking air.
Like Heartbeat said, once you see clear fluid coming out of the brake booster hose, you've flushed the system. Just reconnect the PS return hose, verify the cold fluid level in the PS reservoir and you're done.
Contact Me
Content Web Site
Photo Album
TDP Youtube Channel - New!
Thanks for the info, when I replaced my steering gear the color of my fluid was horrible. Like Black.
Most of the fluid in the system drained out but I need to do another flush to the get the rest.
Is there an inline filter for power steering in these trucks?
No filter... Though one can be added.
https://www.google.com/search?q=powe...hrome&ie=UTF-8
Contact Me
Content Web Site
Photo Album
Yes, inserting a fluid filter in a low pressure line would make the most sense.
In searching PS fluid recommendations here in these forums, I found threads that made the case for synthetic ATF (some by DMaxMaverick). Synthetic fluid will handle higher temperatures better than conventional fluids.
Contact Me
Content Web Site
Photo Album
Adding a low-restriction filter to the return will not hurt anything, but it should be located BELOW the reservoir. The tiniest air leak (even if it isn't leaking fluid) can cause the additional fluid volume to drainback and overflow. The benefits of a return line filter is minimal, IMO. Power steering system issues usually involve pump failure, which will cause issues/failures with downstream components. A high pressure filter should be installed at the pump outlet to maximize system protection. Ideally, both would provide the maximum benefit, along with a cooler (which should also be installed below the reservoir level).
I do not recommend using synthetic ATF in place of OEM recommended power steering fluid. My reason for discussing it is purely anecdotal personal experience. I use it, and have had excellent results. My power steering system issues were reduced by more than half when traditional/recommended fluid is flushed and replaced early (a year or less in a new or repaired system). This is my experience with more than a dozen vehicles over 30 years, with and without using synthetic ATF, but also with coolers installed on most of the trucks. I've used only Amsoil and Mobil 1 synthetics, so can't comment on any of the others.
