Thread: Project from MD
Hybrid View
    Nov 2007
    Hancock MD
    Talking Project from MD
    Hi all Jeremy from Hancock Maryland, thought I had done an intro before but couldn't find it so here is my intro/project build thread.
    truck is a mutt of parts but trying to keep it all GM
    PROJECT NAME--- ARTHAS (from World of Warcraft)
    DRIVE TRAIN & BODY
    1984-GMC--- crew cab 2wd DRW frame
    1988-CHEVY--- crew cab 2wd 4spd cab (hydro clutch)
    1989?-GMC--- SRW bed
    1987-CHEVY--- front clip (single headlight)
    1984-GMC--- J code 6.2 Diesel (stock 112K 1 owner new injection pump)
    1989-CHEVY--- Nv-3500 5spd trans np-241 transfer case (hydro clutch)
    1957-GMC--- 2.5 Ton military axles 6.17 gears
    MISC. & MODS
    2 sets of rear bushwhacker flares made to fit all 4 corners
    425/65/22.5 Goodyear tires from cement trucks
    22.5 x 12.75 wheels
    4-link rear on dodge ram springs (may switch back to leaf spring)
    52" eye to eye Chevy 1/2 ton rear springs up front on custom mount
    2wd steering box for crossover steering (not done yet)
    front hubs flipped in to narrow track
    front 15.3" disk brake rotors instead of drums
    all wheel studs replaced with RH thread
    Eaton M-90 super charger for motor (not installed yet)
    Cucv brush guard on sand blasted bumper (spaced out 1.5" to clear flares)
    steel 2.5" cowl induction hood (to clear charger)
    PLANS
    truck will be getting dual 4" stacks (using 2.5" in and 4" out import mufflers)
    dark blue paint with icicles hanging down from body line
    custom tailgate with plexi glass panel will be back lit
    interior redone basically stock with dark blue and black
    DRIVE THE HECK OUT OF IT really want a big cruiser to take to local shows
    also should mention the jack stand is present in most pics because I have a valve stem that leaks air (oh what fun to dismount and remount these tires by hand)
    Nov 2008
    Tromsoe Norway
    Hi
    Nice little beast you got there, lot of work i guess.
    Looks cool, if we did something like that i Norway, they would shop of the licence plate, and claim it...
    New sub. 1996 6.5 ls 1500.
    1994 Suburban K2500HD. 6,5 TD 251 000km. sold
    3,5 inch exhaust, no cat.
    Marine injectors. Removed snorkle
    opened intake plenum. 3 gauge pillar. EGT.Turbo.Tranny temp. Fsd Cooler, resistor nr 9.
    Top mounted Air to Air intercooler. Kennedy Turbo master
    intercooler is installed.
    look in: http://www.thedieselpageforums.com/t...ad.php?t=37313
    Nov 2007
    Hancock MD
    yeah it wont pass our normal inspections but we have special registrations and tags called "street rod" just for vehicles that have been extensively modified but in return you are only allowed to drive them to and from shows,parades,getting worked on or special occasions. As for the work yeah it began awhile ago I would be able to finish it up real quick if it wasn't for work,money etc lol
