Thread: 6.5/ 6.2 rewiring. need some help ;-)
    Default 6.5/ 6.2 rewiring. need some help ;-)
    Hi again,
    finally it is time to rewire my 6.5 Turbodiesel wich is supposed to go into my 84 chevy k5 blazer.
    I have a new/nos 6.2 engine harness, so I decided to post my questions in this forum.
    Well, here we go, this is what I have:
    1. a nos 82 83 84 interior/dash harness, parts manual says for all models
    2. a late 80s/early 90s matching 6.2 diesel engine wiring harness.
    3. a 700r4 md8 with a manual/pressure converter clutch (transgo)
    4. no emission controls
    well, I already ordered the matching coolant temp sensor for my harness and finally was able to figure out where some of the connectors need to go.
    1.my first question:
    there are some connectors for the engine or emission control module and I do not know if I should remove this part of the harness or not?!
    here is another picture:
    the harness is ment to go into the cab, there are two connectors for the ecm and one other I do not know what function it has ...?!
    ..ok and here is another ?
    2. there are three connectors located close to the big firewall connector.
    two of them are for the wiper, I already tried them out and they fit..
    BUT: what's the third one?
    here we go:
    Lubbock TX, USA
    Probably rear ABS sensor. The other harness going into the cab goes to the 6.2L PCM, mainly for emissions stuff, also for the glow plug inhibit stuff, which is the extra sensor on your other set of pictures in the other thread on the same loom as the injection pump. it's for a sensor.
    This looks like my harness on my 1991 old body style 6.2L Diesel Suburban.
    1986 C10 SCLWB 6.2TD 3.73 700
    1989 V20 SUB 6.2NA, 3.73 400
    1994 G20 VAN 6.5NA, 3.42 60E
    1996 K30 DRW 6.5TD 4.10 80E
    @john8662:
    hey, nice to hear from you again & thanks for your help!
    I'm getting a used harness from 89/90 the next few days, it should have everything I need (ECM, GP Card ... ) to install the new one in my truck!
