I have recently found out about a GM bulletin PIP4526 that addresses collapsing fuel lines. While the C4500 isn't specifically mentioned, the longer run and even higher fuel requirements might cause the same scenario.
Q: Are the same trucks affected each time? If the same, are these trucks heavier, or more likely to be running hills at the time of the stalls?
