Thread: LB7 Injector removal tool
    Jul 2000
    Gilroy, California, United States
    Default LB7 Injector removal tool
    Does anyone have an injector removal tool to loan or sell?
    Matt
    mattb5150@hotmail.com
    1993 K2500 HD ext.cab 4x4 - SOLD
    2003 GMC K2500HD SLT EXTRA CAB/SB DMAX/ALLI, Bilsteins, Sulastic Shackles, Pitman & Idler braces, KD Headlight Harness, CAT filtration, Lift pump w/KD harness, Denali Door handles, Yukon exterior mirrors
    2003 Yamaha Grizzly 660 Stoopider FAST
    1996 VW Passat TDI 48mpg - SOLD
    I don't have one of these either, and I'm not sure I want to spend the $150+ for one. There is an alternative... A local diesel shop has one, and they've agreed to pull the sleeves/cups if I take the heads to them. This might be a solution for others as well - as in take the heads to someone in your area who has the puller...
    Use heavy cardboard to protect the aluminum heads from dents and dings when transporting the heads.
    If I could find my second unit (actually mine) I would gladly send it, but these things have had a habit of not coming back. I used to have 3 of the 6.5 injector sockets. Now I have one. The LB7 tool that I have presently is not mine so I can't loan it.
    I'll have a look around though. My other tool may acrtually be here. Sometimes (quite common) when someone picks up after me things end up where they don't belong...
    Jan 2007
    Spokane Wa.
    I had a local shop pull mine. Tools are nice to have,but how many times are you going to be pulling injector cups?
    Jeff
    When I pulled mine I used an injector line and screwed in the fitting from the fuel rail onto the injector and carefully used an small prybar or rollbar and used the bottom corner on the nut. Useally takes about 2-3 trys.
