Results 1 to 9 of 9
Thread: Front bearing hub
Hybrid View
    Mar 2004
    Springfield, IL
    Default Front bearing hub
    I am doing the front brakes on my 1999 K2500 Suburban and when I got the rotor seperated from the hub it was apparent that the outer hub seal was leaking grease. The bearings otherwise seam fine, the grease inside is clean. Are the seals in the hubs replaceable? Does anyone know what seal I need (part #) and how the hub comes apart.
    Thanks,
    Bill
    1999 Suburban K2500 6.5td, 121k, bone stock
    1992 Ford Taurus SHO
    1989 Ford Bronco-II
    1997 Mustang Cobra Convt.
    May 2005
    SE Wisconsin
    I do not believe that hub is serviceable. It is a sealed unit.
    1997 GMC Savana - 6.5 TD
    1967 Jeepster - Stock
    1986 Jeep CJ7 - Stock
    Feb 2004
    Zionsville, IN
    The hub is a sealed unit, but you can grease it. I use a rubber/vinyl hose that I can squeeze in the ABS sensor hole and shoot grease in that way.
    Jeffrey Todd
    _ _ _ _ ___ _ _ _ _
    '96 6.5TD GMC Suburban 2500 4x4 - 300,000 miles, JK remote FSD, Dual Thermostats
    Mar 2008
    time to change it, hopefully you can get them aftermarket When I needed them they were on national back order and I had to buy them from the dealer
    Mar 2004
    Springfield, IL
    I ordered two from Rockauto for $194 each. It sucks that you now have to spend $400 to replace two $5 seals.
    Bill
    1989 Ford Bronco-II
    Feb 2004
    Zionsville, IN
    Quote Originally Posted by 332bill View Post
    That is pretty good. What kind of warranty do you get? I think AutoZone and Advance have them for around $250 with 1 year, which I think blows considering it is a sealed unit.
    Jeffrey Todd
    _ _ _ _ ___ _ _ _ _
