Results 1 to 20 of 123
Thread: Smaller diesel engine, that would replace a gas inline four?
    Jun 2008
    Only thing is where I live..
    the junk yards are very picked over, theres not alot of selection.. I have to get my family to drive to Edmonton, Alberta, which is about 5-6 hours away.
    You'd be very hard pressed to find a diesel powered car in the yards around Fort McMurray, theres only two here...
    The gas engine in my truck now is known as the "gutless wonder". I'd like to swap in something that has a bit more jam, but still want to get decent mileage.
    Apr 2007
    Alberta, Canada
    Fort McMurray eh...I spent a few summers up there working. Its only about 4 hrs drive to edmonton if you follow the flow of traffic.
    Another thing came to mind, if you decide to venture out of Fort Mac for a motor, you could probably squeeze an Isuzu diesel into your truck. Should be quite reliable and long lasting engine, even if its used.
    Just another though
    2011 VW Jetta TDI, pretty well loaded without leather.
    2006 GMC Sierra D-max, 4x4, 4 door, bumper, winch, Espar heater, and the HID lights are a nice touch too.....
    1986 GMC 3500, 454 on propane, 4 speed, 4x4, crew cab dually......the welding truck
    1984 Toyota 4x4 pickup, 4.3 V6, 700R4, Toyota t-case.......transforming into 4x4 cage buggy
    Jun 2008
    Quote Originally Posted by gophergunner View Post
    Just another though
    I'll keep looking, and if I find anything I'll post it up here.
    Dec 2006
    North Pole, Alaska
    Diesel engines are getting harder to find in the yards as their demand is gaining with the folks making their own Bio with the high fuel prices.
    That's why I still think a 6.2L is a great choice. It'll fit in the 350 convert kit, you can run the stock rear if you don't tow, offroad, or put a turbo on it. It weighs around 700 lbs, a bit heavy, but doable.
    I know many 6.2L's above 300K and running strong. Parts are another fun thing. While the Jetta motor would be smaller and probably give far better efficiency, the initial cost of getting the motor would be much higher me thinks and if you would have to rebuild it, I bet it will cost more. I could be wrong, but look up the costs to have a foreign motor rebuilt. INSANE!!!
    Plus this is a 6.2/6.5/6.6 site. Gotta promote what we work on!
    Apr 2004
    Ottawa, Ontario
    Too bad you aren't back here in the East. There are still lots of VW and Mercedes sitting in junk yards, all rusted out but with good mechanicals. Maybe you would have more luck on the rainy side of the mountains, especially where they use lots of salt on the roads. Buy the whole car as there are bound to be a number of bits and pieces you will need for the conversion.
    Bill
    94 Cadillac Fleetwood (sold)
    08 Aerolight 23TT
    Jun 2008
    Quote Originally Posted by AKMark View Post
    I missed your post last night..
    I'll make some calls around here. How much would a 6.2L used be worth, probably with 200-300K on the clock? What else would I need to make the swap other than mounts and stuff. Engine, trans...
    Oh, and the hydro boost, what is that exactly?
    Dec 2006
    North Pole, Alaska
    Quote Originally Posted by Gearstix View Post
    Diesel motors (for the most part) do not create vacuum like a gas motor so a vacuum powered brake booster won't work with one. Hydroboost uses a line from the power steering pump to power the brakes. You can get this out of any diesel truck, one ton truck and Astro van's use this. It's really easy to convert it.
    You will need a larger radiator, if you go with an auto, get a good cooler for it as well. A RV size cooler is only $75 at Napa.
    If you can get a donor vehicle, you will get everything you need. If you get the motor on it's own, don't forget the alternator, PS pump, A/C compressor (if equipped), starter (these are spendy), and intake box. These parts are not cheap if you buy them on thier own. If the motor has an A/C compressor, it's not hard to set it up with your current system so you keep your A/C.
    Don't forget that after you install your new motor and trans, you will probably have to get a driveshaft as your current one will probably not be the proper length. Having yours modified to fit shouldn't cost more than $300 and if you are lucky will cost closer to $140. A new one shouldn't be more than $400 and depending on the shop might be even cheaper than resizing yours.
    Your current guages will probably not work with this motor as your ECM will probably be wondering why the injectors and O2 sensors are. I would consider pulling the dash and replacing with aftermarket guages, or at least pull the check engine light and that way it doesn't tick you off being on all the time. The guages might work if you wire them the to proper sensors, just be prepared if it doesn't. Your Tach (if so equipped) will take a bit more work to make it work. I don't know how to start on that one, but there are some resources here that might be able to help you.
    FYI, in a 1985 4x4 Suburban with 31" tires, and 3.54 gears I was getting 24 mpg with a 6.2L, in my 91 with 31" tires and 3.73 gears, I got 22 mpg most of the time. If two 6K vehicles can get this type of mileage, your 3K truck should do quite a bit better. If you can get 3.27 or 3.07 gears you'll probably get over 30, but there are no guarantees.
    May 2005
    SE Wisconsin
    GM offered an S10 with an Isuzu, IIRC, 2.2l diesel. That might be an easy conversion. Isuzu also sold the clone vehicle. Unfortunately, those vehicles are not very common.
    1997 GMC Savana - 6.5 TD
    1967 Jeepster - Stock
    1986 Jeep CJ7 - Stock
