Originally Posted by
More Power
EGT.... I heard from a non-turbo 6.2L owner a few years ago who ran his truck at 1000-1100 degrees for several hours. He was in a hurry, towing a trailer, and ran it to the ECT limit all during that time. He reported it still ran fine afterward. I'd have been sweating....
Jim,
When my '81 was naturally aspirated w/stock CR, I saw EGT's up near 1300 and spikes up to 1400. Towing my 5th wheel (like I did to Dayton in '01), I regularly saw 1100 to 1200 for hours on end. It never seemed to bother the engine.
Installing the turbo and 4" exhaust with no other mods reduced the EGT's to a max. of 1050 at 14 psi.
When I rebuilt the 6.2L a few years ago, there was really very little cylinder scoring, just some slight piston damage. It was running just fine at the time. I only pulled it to replace lifters and a few other things, and then those "might as wells" started kicking in...
I don't think high EGT's are nearly as critical on a n/a engine as they are on a turbo'ed.
