Results 1 to 20 of 29
Thread: 6.2/6.5 Diesel Conversions - The High Points
    Oct 2012
    Ohio
    I have a 1990 Chevy K2500 with a 6.5 V8 Turbo Diesel in it. I was woundering what kind of motor(s) I could swap out and also what else I would have to swap for the gas motor. And could I keep the turbo for the gas.
    Dec 2003
    Yukon Canada
    Hi
    Any GM truck engine will fit,250 6cly,283-400 small block,or 454 big block.
    You will have to go to a carb and distributor.Unless you want to swap in the wiring harness from a gas truck of the same vintage.If you have an auto trans you will have to change the tourge converter.And no you can't keep the turbo from the diesel and use it on the gas.
    You would be further ahead to replace the diesel engine.You say it's a 90?
    If so someone has already replaced the engine,it would have come with a 6.2 mechanical injected,and no turbo.
    Whats wrong with the engine? Lots of help here if you want to fix it.
    Thomas
