Quote Originally Posted by Margo_325 View Post
Im doing conversion on a 1995 Suburban. Donor car is 2001 Silverado. I have the book "Duramax 6600 Conversions&Repower Projects"
My Suburban does not have an HVAC like in the book, I took all the wiring out behind dashboard (I want to keep the old dashboard), that included all heater wiring as well. Do I just have to compare two car wiring diagrams and search for right wires to connect to heater plugs?
I only left the wires, that came out from drivers door and went behind dashboard to passenger door. How did you get your power windows and central locking to work, I didn´t find anything from the book, how to connect them.
Margo, Estonia
Your complete HVAC system & control panel should work just like mine does, meaning it'll operate as a standalone system. You'll just need to tap into DMax HVAC under-dash wiring for power/ground/AC clutch engage. I recommend using the Dmax HVAC power and lighting circuits so the correct the fuses are being used. The 88-94 diagram in the book can be used as a guide for your 95 system, but you will likely need the 95 wiring diagram to double-check it.
As was mentioned by THEFERMANATOR, the ECM will be looking for the Dmax HVAC controller. I didn't need to delete that function in the ECM using EFI-Live, but it wouldn't hurt.
If you want to maintain 4-wheel ABS, I would transfer the Dmax truck's ABS controller and related hardware to the Suburban.
And by the way, I consider the Dmax instrument panel essential for the best conversion (the gauges are right and you'll have the DIC).
