Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
Thread: 6.5 Girdle
  1. #41
    Oct 2011
    Northeast GA
    Jim,
    Do you have any more information about Mr. Ashwill and his girdle?
    1992 Suburban, J-code 6.2L from CUCV, 700R4, NP241
    9" lift with straight axle conversion, HP Dana 44 with Loc-Right in front, Dana 60 with Detroit in rear, 4.10 gears
    37 x 12.50R16.5LT HUMMV tires (rolls out at 35")
  2. #42
    It's been a couple of years since I last received an email from Andrew. At that time, his engine/truck was still running great.
  3. #43
    Oct 2011
    Northeast GA
    I was wondering if he had ever offered this service.
  4. #44
    It's too bad we can't get the girdle used on the new P400. I'd think that it could (& the older blocks could) be modified to work together. Jim
  5. #45
    Oct 2011
    Northeast GA
    That would be awesome. Maybe someone that has one might do a trial fit for us.
  6. #46
    To date, AM General hasn't made engine components available separately. So, I doubt they'd release the girdle as a separate item. Too bad...
  7. #47
    Jun 2017
    raleigh nc usa
    Default 6.5 main stud girdle
    Quote Originally Posted by 82blazer View Post
    I have came up with a design that covers all 5 main caps but I seemed to have reached a snag I'm having trouble locating bolts. I need 12x1.75x85mm. any ideas? These things fit but I need longer bolts. Studs won't fit under the pan on the #1 main cap.
    Has blazer or anyone developed and installed a main girdle? Other than the sweet alumimum one. Id like to learn from the experience of others before plowing new ground. Is anyone producing one that connects all main caps. I know that a custom oil pan would be required. Thanks for your input and patience.
  8. #48
    Jun 2017
    raleigh nc usa
    Default main stud girdle blazer
    Is the stud girdle still performing well? Did you make or are you making kits for sale. I can build my own but if someone has already done it and it works why rock the boat?
