Results 1 to 20 of 22
Thread: Local Regs on Bio Diesel
Hybrid View
    Jan 2005
    St. Louis, Missouri (pronounced misery)
    Default Local Regs on Bio Diesel
    I don't live in one of those subdivisions that tells you what color your car has to be. However, I do live in a fairly old and rigid suburban city. I would like to experiment with making my own Bio-Diesel, but I am certain that just about the time I get it all set up they will shut me down as being hazardous to my neighbors. (I'm sure that the fact that I am not really paying taxes on it shouldn't factor into the equation though)
    Has anyone tried or run into this situation? I mean it's just vegetable oil until I mix it correct? I'm sure someone somewhere has a rationale for calling vegetable oil a toxic substance. I don't want to ask, but I don't have a choice, it will have to be stored outdoors in plane sight.
    Scott
    St. Louis, MO
    '06 Silverado K2500 4x4 Crew Cab D/A "Big Max" AmpResearch retractable Running Boards, 4" Turbo back Kennedy Exhaust, Kennedy Custom Tune!
    '99 BMW K1200LT "Special K" my other "SUV"
    '07 Salem by Forest River Fifth Wheel Toy Hauler
    Mar 2007
    Pacific Northwest
    Cool
    Please Please Please
    Go to your local GM dealer and ask them what they think of the BIO-DIESEL before you even think of using it! I work exclusively on the D-MAX engines and I have seen nothing good come of using the bio-diesel in the high pressure fuel systems that the D-MAX engine uses. The fuel gels too easily, the filters plug too easily, and the fuel pumps go "SOUTH" too quickly. The bio-diesel is probably great stuff for the old 6.2 and 6.5 diesels (low pressure fuel system) but it is causing toomany problems with the 5.2, 6.6, and the 7.8 D-MAX diesel engines.
    Jan 2005
    Quote Originally Posted by Duramaster
    Hmmm, how do you really feel? That's good advice! I hadn't considered the high pressure fuel system and the potential problems there. Honestly, I don't have the facilities or really the time to mess with making the stuff.
    There's something to be said for reducing the amount of oil we buy, as well as the feeling I get by being self sufficient. But I don't want to do more harm than good!
    Scott
    St. Louis, MO
    Sep 2006
    Delaware
    Hey Scott....
    Great question and one I've been toying with as well. First let me jump into the above quote. Please take this for what it is... an opinion. Although I've read bunches and bunches of articles going back and forth about the benefits and dangers of bio-diesel... I have never actually opened an engine for myself. So, Duramaster please know that I am not trying to say that "you don't know" because you do. If you could follow this up with some of your experiences I think that would be great!
    I think most of the above observances from Duramaster has to do with the broad use of the word "bio-diesel." Biodiesel is often used for everything from B20 to B100 to SVO and everything else in between. B serieses uses a ratio of B100 (which is vegi-oil chemically reacted/blended with methynal) and regular dino-diesel. SVO is "Straight Vegi-Oil." There are some around here that blend kerosene and vegi-oil and call it "biodiesel." Around here all that's available commercially is B20.
    I've read that B20 is no different than #2 or winter blended dino as far as gelling (mainly because 80% IS #2 or winter blend), and I've had no trouble with it. I haven't heard much about the B100 because of it's inavailability here. SVO will gel at 40*... but then again, it's Straight oil. I think issue is more likely to be water. Especialy in the "less" controled environment of the backyard brewer.
    The filters should live just as long in bio or #2. The issue here is that #2 is dirty and likes to leave calling cards behind, thus the need for a filter. B100 has a detergent quality because of it's alcohol content and likes to clean out the fuel tank and lines. Naturally, if a vehicle's life starts out on #2 there will be deposits in the fuel system and when a detergent is added.... the filter gets worked more than normal. If the owner switches frequently, which is often the case because B100 is not at every pump, then contaminants are again reintroduced into the fuel system and the cycle continues. If at all possible, B100 should be used by it's self and regularly. The filters should be changed frequently at first until the grime is removed then at normal intervals. B20 or B50 I feel is just a compomise. It makes me feel like I'm saving the planet while keeping my wallet. In this senario or with B50 or any combo containing petroleum diesel the filter will be catching what is left behind by the petro and cleaned out by the bio. SVO's "dirtiness" is based on whether it's used oil (frier oil) or not and how well it's filtered before use.
    I don't know much about the IP failures... but from what I understand B100 is similar in viscosity to #2 and should (in mind oval head) respond to high preasures similarly. The only thing I can thing of is that of the dirtied filters no longer working and the IP being the next in line. Injectors would follow.
    To wrap things up I think it would be very difficult to name "biodiesel" as dangerous or bad with our first nowing exactly what is being used.
    Scott... one regulatioin you'll need to be carefull of is the one that says it's illegal to run a "meth-lab." Form the prying eyes of a neighbor or a public official (cop) a man buying 50gl drums of methanol to cook biodiesel looks a lot like a man buying the same for "Crystal Meth." Be sure to be upfront and open!! The more obvious, the less chance of a missudrestanding at the "Ok Corral!!" The other is to let the local FD and fire marshal know what's in the shed or garage. They like to know where the explosives are when called to a fire!! Any other regulations would be at a local level as biodiesel on the homefront is unregulated below a certain amount of production that's for personal use. Here's a great link I've got tucked away that may be of help!
    http://www.utahbiodiesel.org/biodiesel_links.html
    Good luck!!
    '96 C3500 Crew SRW, 228k, auto, 4:10, 265X75r16
    'PolarFlo' FSD Cooler
    1966? Covered Wagon 9'-10' Slide-In camper
    '03 VW Golf TDi (Stock) - +40's mpg (avg)
    "Any boy can be a Father... it takes a man to be a Daddy!"
    There should be NO ALCOHOL in the final product of biodiesel. If there is, you are not processing it properly. Methanol is used during the cracking process, then removed if done properly.
    A meth lab is very different than a bio lab. The only similarity is both use chemical cracking to convert one base product into a different end product. The processes are very different, and very different chemicals are used. Methanol/ethanol is used for some meth recipes, but not all. Any experienced "cop" would know the difference with very little investigation.
    The "solvent" quality found in bioDiesel is also present in the WVO/SVO itself. Both VO and bio have similar solvent qualities.
    Correct processing and filtering is the key. If all is done properly, the end product will be free of alcohol, and contain no more than the acceptible amount of water. All Diesel fuel contains water (as does all motor fuels). As long as the concentration is below the acceptible level, it is no problem. Processing, handling and storage will determine the water content.
    Sep 2006
    Delaware
    Quote Originally Posted by DmaxMaverick
    Though you are right, Dmax... you can't always count on an experienced officer being sent to investigate, or an honest neighbor understanding your intentions. It never hurts to cover your bases.
    I had the reaction backwards..... I thought the alcohol replaced the glycerin and went with the esters... but it replaces the esters and goes with the glycerin to prevent reversal. I think... man I wish I had a better chem. teacher who didn't "smell" his work so much!!
    Dec 2006
    Lancaster, PA
    Quote Originally Posted by baker2acre
    Baker: the methanol is reacted with SVO or WVO, and using a catalyst (heat & either sodium or potassium hydroxide), in fact does replace the glycerin molecule at the end of the triglyceride with an alcohol molecule thereby creating a "methyl ester." The primary problem with this is that the reaction is usually incomplete meaning that not all of the triglycerides (glycerin & the 3 fatty acid chains) have been "changed." This leaves a little bit of excess methanol floating around in your biodiesel. While some of it settles out with the glycerin at the bottom of the reactor, Dmax is correct in saying that what's left in the biodiesel must be removed before running it.
    Scott: not a good idea to store it outside "in plain sight." Just gives people reason to question. Better to keep it indoors, under your hat & in your tank. Also not a good idea to stockpile methanol in a drum. Having a small bomb sitting around is what makes people nervous, regardless of your intent with it. Buy what you need for the batch and use it up...
    95 K2500 6.5TD, Ext cab, short bed, 123K, FSD Remote, minor overhaul @ 123K: new injectors, glow plugs, glow plug relay, injection lines, heads, exhaust manifolds, harmonic damper & idler damper, water pump, (timing chain at 3/8" play) 4" exhaust, K&N air filter, CDR valve, trans cooler lines, alternator. Dead Kitty & deactivated EGR. (MPG: 11.5 before work listed, 13.5 afterwards & 17 w/ Marvel Mystery Oil)
    Dec 2006
    Bainbridge Island, WA
    I hear what you're saying. I'm not arguing, just not understanding. As far as gel point: Got it. No issues. As far as filters clogging. You said one was on an engine with 2,000+ miles. What clogged it? I mean, if you start using Bio-D on a new engine, there aren't any deposits left from dino-diesel over the years to break loose, This must mean that the bio-D itself has particulate matter that clogs the filters. Comments there? I have a friend who used bio-d in an old Mercedes diesel, and the filters clogged several times. Of coursem the car had 200K miles on it.
    Also, I'm trying to figure out what is different about bio-D versus dino in terms of viscosity that might be an issue in a high pressure system. I found specs on two points: Specific Gravity of Bio=0.87-0.89. SG of Dino = .82-1.08. Kinematic viscosity of Bio=3.7-5.8. Viscosity of Dino=2-6. In both cases the bio-d numbers fit inside the greater dino number variations. As far as I know, 'viscosity' is a measurement of 'thickness," Right? Is there another measurement that shows bio-d to be way out of line from dino?
    Any info appreciated. I'm really trying to understand what the differences are here.
    * 07 Classic Duramax Xcab LB in Victory Red! *
    Red face
    Let me know when one of the tree huggers comes up with a way to brew diesel from scrap wood.
    I'll stop tossing all the dunnage (sp?) that goes under the steel and poly pipe I haul for a living, and drag it home to make tomorrow's go-juice!
    Jan 2007
    I read on the dodge forums that the high pressure fuel lines causes the fuel to plasticize and messes up the injectors. However, I have no proof and would like to see a motor than has been run 100k miles of B-100 torn apart and looked at to compare to another engine run solely on dino diesel.
    I would like to make Bio-D and I have a source for WVO that would give me 10 gal a week. Having some problems locating methanol locally. The lye is easy as it can be shipped easily.
    However, nothing is worth messing up a 16k+ motor, so.... I would only run it at b5 level after I got good enough at it to pass ASTM specs. Yes, I would give up the initial savings by paying to get it tested.
    We don't even run winter blend fuel here, so I am not worried about gelling. I can only remember 1 day where it got to 40 degrees last year.
