Electrics you see used in production all come on with A/C. Some have two fans. One of the two fans may be dedicated to the A/C and the other fan could still be off.
By the way almost all electric fans I have seen were on vehicles that did not have an option. Either due to motor alignment or positioning in the vehicle, or lack of room.
Also I pretty much run my A/C all the time if needed. If it's hot, or if the windows are fogging up. In humid areas it's needed a lot.
95 C1500, IC, 3" to 4" Exhaust, Turbo Master, Max E Torx.
