98 Chev x-cab 4x4 6.5
No muffler or cat
The ABS light will go off when the truck is restarted but comes back on as soon as the truck starts to roll ahead or backwards without even touching the brake pedal.
Although this would be nice to have fixed, just for peace of mind, I sure to enjoy the way the brakes work without the ABS more than when it was working. I can finally feel what the front brakes are doing on the ice and can more easily tell when the wheels are getting close to locking up and skidding.
If anybody has any ideas on what the ABS problem might be, I sure would appreciate your 2 bits worth.
I had some electrical problems which disable the ignition switch, put all the gauge lights on and disabled the front diff lock switch. This turned out to be a bad ground wire on the back passenger side of the intake manifold.
debles99
