Fuel Leak
Hello everyone, A litle fuel problem.
1993 6.2L
I have a leak at the top of the filter mount assembly. I replaced the water bleed screw about 6 months ago. When i blow fuel residue off filter block, and start the engine i am getting some diesel mist when i hit it with compressed air again. Is it possible that the heater is leaking or should i go ahead and get a new bleed screw?
The rubber on the bleed screw is still soft.
Suggestions?
Thank you,
Ken
- You may not post replies
- You may not edit your posts
Forum Rules
