Yep
Originally Posted by
TurboDiverArt
I assume you put this in series? Meaning you cut the signal wire going from the VSS to the VSSB and put the ERA in the middle? That way the VSSB knows the actual speed as modified by the ERA but thinks the gearing is still stock?
Art.
Yes, that's it.
As for engine management on the 1999 6.5 w/NP246 the vss output signal @ pin C-11 from vssb does not connect to pin F-13 (speed signal) @ pcm.
