NEED Resistor info
Originally Posted by
rjwest
try the resister to fool the tcc lock up, stay in 3rd gear, tcc should stay locked above 45 mph, don't use 4th on a hill, down shift manuel...
2nd gear will also lock tcc about 32 mph...
but you have to shift manuelly, as Trans will be in high pressure mode,
Need to shift like it's a std shift, un-throttle and match rpm to drivetrain.
I installed a sw for the TCC lock up, and a sw for the 3-4 shift,
2 sw's by the console to control shifting...
I'd like to try this, what's involved?
