Results 1 to 20 of 138
Thread: Is it worth changing gears for better MPG's???
Hybrid View
    Apr 2004
    Palm Beach, Florida
    Default Going Back To The 4.10's
    Been mulling this around for some time now and decided to go back to the 4.10's.
    Will have the 3.42's on the market soon, frt 9.25" ring w/pinion, rear 10.5" ring w/pinion.............
    Feb 2002
    Maine/Florida
    try the resister to fool the tcc lock up, stay in 3rd gear, tcc should stay locked above 45 mph, don't use 4th on a hill, down shift manuel...
    2nd gear will also lock tcc about 32 mph...
    but you have to shift manuelly, as Trans will be in high pressure mode,
    Need to shift like it's a std shift, un-throttle and match rpm to drivetrain.
    I installed a sw for the TCC lock up, and a sw for the 3-4 shift,
    2 sw's by the console to control shifting...
    1996 K3500 EX-CAB 108K MILES
    MODS:UnderDASH PMD,38G Aux Tank
    ISSOPRO BOOST&EGT,Fuel Pres Gage
    CSI Oil & Trns Temp Gages
    BD DOWNPIPE, Rem Oil Filter
    Dual inline LP/Filter SOLD AT 130K MILES, Know GM LESS
    Apr 2004
    Palm Beach, Florida
    Question NEED Resistor info
    Quote Originally Posted by rjwest
    I'd like to try this, what's involved?
    Feb 2002
    Maine/Florida
    50 ohm resister accross the tran emp sensor to ground, through a switch.
    this will allow the TCC to lock up at 40 mph for a 3.73 gears,
    allow 2nd to lock the tcc at 28 mph for 3.73 gears.
    4th , mph not affected,(abot 50 mph tcc lock up)
    But the TCC will not unlock, will hold untill down shift , ( very harsh shift ) thats why you need to manually shift,,,
    Note all all your speeds will be about 10 per cent higher, with the 3.56
    ( there are posts on the resister. ).....
    for the 3-4 gear shift, need a switch in one of the 3 shift control lines,
    that go to the trans,leave in 4th, open switch and it will downshift to 3, close for upshift.
    I will have to look in my manuel to find which wire it is, will get back to you,
    Note: if you forget and leave in 4th lock out ( 3rd gear, sw open )
    and restart engine, a code sets that makes a harsh shift,,,
    I was working on a 2-3-4 shift box, with a lock out relay, to prevent
    the code problem but sold the truck.
    If you have a code reader, setting code is not a problem as a code clear resets it.
    will get back with more info..
