bleeding
attach a vacuum type brake bleeding pump to the output side of the fuel filter, works great if mechanical lift pump, electric-don't know, sure saves beating on your starter motor. still no go-you gotta bleed the lines at the injectors.... with the starter. crack'em all loose a turn or 2 then crank until at least a few or all start weeping fuel then retighten and.................
