Results 1 to 6 of 6
Thread: Oil pan plug gasket? Dumb question?
Hybrid View
    Jun 2000
    Morrisville, VT, USA
    Question Oil pan plug gasket? Dumb question?
    The local quick-lube place changed my oil and filter for me the other day, and there was no gasket/washer on the plug. He almost busted a box-end wrench getting it out. The D-Max is new to me, so I have no way of knowing if there was a factory installed plug gasket on it or not. In the end, he put a nylon gasket on, and tightened it down quite tight. I don't think they had a torque spec for it, and neither do I. I know this has been asked before, but here it is again. Is there supposed to be one there or not?
    Thanks.
    Dick Wells
    Owego, NY
    Dick,
    I just looked at the plug that (I think) came with my 03 and it’s a standard GM type plug with an integral rubber gasket. The gasket can be removed and replaced.. seems like a separate nylon gasket should work OK too. I looked up the torque spec on www.alldatadiy.com and it’s listed as 62 ft-lbs I was surprised it that that high! I would have guessed 24ft-lbs … At the first change I replaced the plug on my 03 with a Fumoto Valve which uses a flat fiber gasket... at 5kmi it was changed it to a special oil bypass filter return fitting that also used a flat fiber gasket.
    Bill
    98 K3500 6.5,SOLD
    Jun 2000
    Thanks Bill.
    I'm not losing any sleep over this. I just check for seapage every day, and I'll take a wrench to it before I head back to Vermont. I keep fairly close track of these things anyway. I'll bet some of the old DM hands will check in on this with the official dope. I know it must have been asked before.
    Dick
    I didn't really pay too much attention, but I think it's a replaceable gasket with a sort of "cast in O-ring".
    Owego, NY
    [QUOTE=jbplock]..I .. looked at the plug that (I think) came with my 03 and it
    Bill
    98 K3500 6.5,SOLD
    Jun 2000
    Smile
    Thanks Bill.
    Couple of things come to mind, neither one of great importance. One is that the filter that came off was an AC, and it was likely that Brown Automotive in Del Rio, where I got the truck, most likely changed the oil and filter, because the sticker on the windshield showed that I had to change the oil about the time that I actually did. So, if a GMC dealer did the job, then it should follow that they would do the right thing. Well, if they messed up it wouldn't be the first dealer to do so. So, I still really don't know, do I?
    The other thing is that my son back home has an 03 with the LB7, so when he un-caps his, maybe we can tell.
    Also, we have a complete set (5) of Helm manuals for the 03 at home. If we can't find the straight poop in there, it won't be found anywhere except from the guys who bought LB7s and either had a seal on the plug or not.
    Thanks again,
    Dick
