Does anyone know if there is a static OHM check for the accelerator pedal assembly. I have a 95 6.5TD extd. cab dual wheel C3500. I changed the pedal assembly at $340 but still get the code. I have a hysteresis issue with initial pedal movement on every new key start. After the first start the pedal responds correctly. The wire dirgram in the book I have is no help. I have changed the ECM in the past and transfered the Eprom from old to new without any problem but from all the posts I have read the Eprom could very well be the problem. After utilizing the GM dealer way too many times for code reads I am not so sure everytime it says pedal that it is correct. Down stream components are most likely the problem here. Does anyone have any tribal knowledge on where I should check. I am a structural mechanic on C-130 aircraft and I keep a ledger on weird issues and fixes so the troubleshooting path is not lost. I would appreciate it if anyone has experienced this pedal issue. Thanks for the input so far. I am on my second accelerator pedal assembly. I will do the voltage test tomorrow.
[ 02-16-2006, 08:42 PM: Message edited by: vintagehardwoods ]
