Yes you will need a retention clip for the front drive shaft and a gasket that goes between the transmission and the case housing. If they try to sell you the clip with the case housing that cost around 8 bucks tell them to make a key ring out of it. On second thought do not make a key ring out of it because you will most likely lose your keys when it breaks
