If I order a new case half and have a shop replace it and install the part I bought from Kennedy are there any other parts to order from GM with the case, seals etc. that are necessary to do the job correctly?
Matt
Matt
mattb5150@hotmail.com
1993 K2500 HD ext.cab 4x4 - SOLD
2003 GMC K2500HD SLT EXTRA CAB/SB DMAX/ALLI, Bilsteins, Sulastic Shackles, Pitman & Idler braces, KD Headlight Harness, CAT filtration, Lift pump w/KD harness, Denali Door handles, Yukon exterior mirrors
2003 Yamaha Grizzly 660 Stoopider FAST
1996 VW Passat TDI 48mpg - SOLD
Yes you will need a retention clip for the front drive shaft and a gasket that goes between the transmission and the case housing. If they try to sell you the clip with the case housing that cost around 8 bucks tell them to make a key ring out of it. On second thought do not make a key ring out of it because you will most likely lose your keys when it breaks
