SoomisDuramax,
You have a blown fuse or you have pulled a Fuse/wire out enough it's not making contact or cut a wire..
Your symptoms sound like the TCM (Allison Trans Computer) is not powering up.. Please Check (with a test light) "IGN 0" fuse and wiring which is located in the side panel at Drivers door..
Hope you get it fixed..
[ 01-04-2003: Message edited by: SteveO ]</p>
