The ideal way is to replace the same anount you take out..Drain and measure what you remove, then fill with same amount..
I check my fluid once when new and do not check it again unless it leaks or till a change..I park on concrete..
Just the way I do it..Hope this helps.. [img]smile.gif[/img]
